Old 09-07-2011, 09:44 AM   #1
Low water Pressure with water softener
I have low water pressure in the house when the water softener is on (not bypassed). When the water softener is bypassed the water pressure is great. What in the softener would be causing this?
garden is offline   Reply With Quote
Old 09-07-2011, 10:45 AM   #2
Water Treatment
Could be that there is some thing in the valve cutting the flow.
Could be that there is a large build up in the media cutting the flow.
When was the last time the unit did a regen or cleaning cycle?
What brand is the unit?
What is the water quality?
There are a number of could be's and maybes......
Akpsdvan is offline   Reply With Quote
Old 09-07-2011, 12:31 PM   #3
A couple of additional questions:
1. Is this condition new--that is did you have satisfactory pressure in the past with the softener in service?
2. Do you know what type of resin is in the softener--fine mesh for example?
3. Does the pipe size reduce as it goes to/comes from the softener?
Bob999 is offline   Reply With Quote
Old 09-07-2011, 03:59 PM   #4
Softener brand is CSI and is 7 years old. Do not know the resin type. Not sure when the last regen was but is done on demand. Noticed pressure changes a couple of months ago when 2 fixtures working at same time. Has been happening off and on but seems to be oftener now. Pipe size stays the same to and from the softener. We have hard water due to limestone in the ground.
Thanks for responses.
Old 09-07-2011, 04:11 PM   #5
As a first step I suggest an extended backwash. To do that initiate a manual regeneration and when the unit begins the backwash cycle unplug the control heat and let run 20 minutes before plugging the unit back in and then let it complete the regeneration. Then check to see if the situation improved. If so you may need to adjust the programming to increase the length of the backwash.
Old 07-30-2012, 08:40 PM   #6
what is control heat?
gjgogol is offline   Reply With Quote
Old 07-30-2012, 09:11 PM   #7
A misspelling for control head.
Old 07-30-2012, 09:43 PM   #8
water softner needs backwashed....
The Following User Says Thank You to ben's plumbing For This Useful Post:
Bob999 (07-30-2012)
Old 07-31-2012, 02:03 AM   #9
thank you...i should have guessed...i have a similar low pressure problem right after i replaced the control head pistons. i did not regen so maybe that will fix it.
The Following User Says Thank You to gjgogol For This Useful Post:
ben's plumbing (07-31-2012)
what is the thing called that stores water under pressure for low water pressure? oregongirl23 Plumbing 18 08-08-2010 03:09 PM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 10:16 AM
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 10:24 PM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 07:04 AM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
