-   -   Low water Pressure with water softener (http://www.diychatroom.com/f7/low-water-pressure-water-softener-116494/)
garden 09-07-2011 09:44 AM
I have low water pressure in the house when the water softener is on (not bypassed). When the water softener is bypassed the water pressure is great. What in the softener would be causing this?
Akpsdvan 09-07-2011 10:45 AM
Could be that there is some thing in the valve cutting the flow.
Could be that there is a large build up in the media cutting the flow.
When was the last time the unit did a regen or cleaning cycle?
What brand is the unit?
What is the water quality?
There are a number of could be's and maybes......
Bob999 09-07-2011 12:31 PM
A couple of additional questions:
1. Is this condition new--that is did you have satisfactory pressure in the past with the softener in service?
2. Do you know what type of resin is in the softener--fine mesh for example?
3. Does the pipe size reduce as it goes to/comes from the softener?
garden 09-07-2011 03:59 PM
Softener brand is CSI and is 7 years old. Do not know the resin type. Not sure when the last regen was but is done on demand. Noticed pressure changes a couple of months ago when 2 fixtures working at same time. Has been happening off and on but seems to be oftener now. Pipe size stays the same to and from the softener. We have hard water due to limestone in the ground.
Thanks for responses.
Bob999 09-07-2011 04:11 PM
As a first step I suggest an extended backwash. To do that initiate a manual regeneration and when the unit begins the backwash cycle unplug the control heat and let run 20 minutes before plugging the unit back in and then let it complete the regeneration. Then check to see if the situation improved. If so you may need to adjust the programming to increase the length of the backwash.
gjgogol 07-30-2012 08:40 PM
low pressure using water softener
what is control heat?
Bob999 07-30-2012 09:11 PM
A misspelling for control head.
ben's plumbing 07-30-2012 09:43 PM
water softner needs backwashed....:yes:
gjgogol 07-31-2012 02:03 AM
control head
thank you...i should have guessed...i have a similar low pressure problem right after i replaced the control head pistons. i did not regen so maybe that will fix it.
