Low Water Pressure On Kitchen Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-08-2010, 12:20 AM   #1
Rewards Points: 16
Low water pressure on Kitchen faucet
I have a Taymor Kitchen faucet with the pull out sprayer (the faucet is also the sprayer). All a sudden, the water flow becomes very slow. I put a bucket under the sink and disconnected the sprayer hose. Water seems to come out OK. The bucket filled quickly when I turn on the water ( hot or cold or mix). I suspect that the problem is with the sprayer or the hose. I then reconnect the hose and disconnect the sprayer. Flow is slow when I turned on the water. This means that the problem is with the hose.
With the sprayer disconnected, I can see the end of the hose connecting to the sprayer is like an empty hole. However the end connecting to the faucet has something like a white plastic plug inside. It seems that the plug can move in and out slightly inside the hose. Is that some kind of valve or flow restrictor ? if it is, can I remove it ? When I say remove, it think I probably has to use a drill to drill throught it. It seems to be an integrated part of the hose. I like to get some advice before I take this action. Any other suggestion will be greatly appreciated.
DIY_user is offline   Reply With Quote
Old 01-08-2010, 07:08 AM   #2
There is a aerator screen, just like any faucet. That may be clogged, or the sprayer head it self is faulty. Replacements are usually available at big box stores, or plumbing supply stores that specialize in that brand..
Old 01-08-2010, 08:09 AM   #3
Rewards Points: 16
I removed the entire sprayer head. So it is just the sprayer hose connecting to the faucet water source. The screen in the sprayer head is not in the picture.
Old 01-08-2010, 01:08 PM   #4
<deleted>
TitaniumVT is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Questions about water pressure regulation.. MrSimmonsSr Plumbing 20 11-30-2012 10:43 PM
Water pressure dropping tucsoncop Plumbing 2 04-25-2009 01:19 PM
Low water pressure upstairs but gauge reads 100psi? rivers72 Plumbing 7 11-15-2008 08:55 PM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 07:55 PM
