Low Water Pressure - How To Discover Issue? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-01-2013, 09:53 AM   #1
Rewards Points: 161
Question
low water pressure - how to discover issue?
I just moved into this house, built in 1977 ... I noticed if you flush the toilet in one room, bathtubs, sinks, everything in the houses water pressure basically disappears.
How can I start debugging this if you will?
vivithemage is offline   Reply With Quote
Old 04-01-2013, 10:11 AM   #2
Rewards Points: 452
Debugging can commence by stating whether your water source is from a well or municipal system. A reasonable guess at this point would be there is a problem between the supply source and the house. Start at the most distant end of the system from the supply and work backwards until a good flow and pressure is found and maintained. Hopefully this will narrow down the area the problem is in.
SeniorSitizen is offline   Reply With Quote
Old 04-01-2013, 10:17 AM   #3
need more info. do you have city water or are you on a well? what type of piping do you have? is the main valve open all the way? did the house set empty for a while?
Old 04-01-2013, 10:18 AM   #4
Rewards Points: 161
municipal ... there is a water tower 2ish miles form my house, if that is even where it is coming from. Is there a simple way to measure flow?
Old 04-01-2013, 10:18 AM   #5
Rewards Points: 161
This is my first house ... i'll have to check when I get home!
Old 04-01-2013, 10:31 AM   #6
Rewards Points: 452
Flowing water into a pail/ bucket for one minute is about the simplest way I know of. That method will give time and amount. Pipe size will be a factor but not at this point. We're looking for a culprit now.
Old 04-01-2013, 11:10 AM   #7
Rewards Points: 161
Where should I have it flow from? nearest to the municipal water entrance to my house?
Old 04-01-2013, 12:01 PM   #8
Rewards Points: 452
If you open a valve farthermost from the house supply entrance and while it is open if a fixture closest to the water supply entrance to the house is opened and has little to no flow I'd suspect the problem to be between the second fixture you opened and the meter.
Good flow at the entrance point would indicate a problem within the house.
Old 04-01-2013, 01:15 PM   #9
Rewards Points: 452
Do you have an outdoor hose bib / hydrant you could check flow from?
Old 04-01-2013, 01:17 PM   #10
Rewards Points: 1,706
What size water piping did they use?
Old 04-01-2013, 11:08 PM   #11
Rewards Points: 161
okay, so I turned the shower on ... furthest away, and then the sink, which is maybe 8 feet off the house line in ... and it was dismal ... should I just call the city out to look at it? It looks like the majority of the copper was updated, as a lot of it looks pretty new, and they are 1/2"
Old 04-02-2013, 03:02 AM   #12
Rewards Points: 744
Do you get good flow from any faucet or hose bib?
Seattle2k is offline   Reply With Quote
Old 04-02-2013, 11:05 AM   #13
Rewards Points: 161
yes, if it is the only source of water running ... so if I turn on the furthest shower/faucet it is decent, but then I turn on something else in the house, util sink (1-2 feet from line in) they both are low/slow.
Old 04-02-2013, 11:19 AM   #14
Plumber
TheEplumber's Avatar
Rewards Points: 356
Do you know your water pressure?
Old 04-02-2013, 11:30 AM   #15
Special User
Rewards Points: 1,230
Sounds like either the plumbing is too small, or, the pipe between the meter and the house has become clogged with mineral deposits -- especially if galvanized pipe was used.
If your whole house was recently replumbed with copper, 1/2" for the mainline is too small to meet code. Did the previous owner use a professional plumber? Was a permit pulled / was an inspection performed? 3/4" is generally the minimum, with 1" being used for the mainline in many cases. 1/2" can generally only be used after splitting off the mainline and feeding a single fixture. If the mainline is a mere 1/2" then I would certainly expect exactly the sort of problem you're experiencing.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 03:35 PM
Water Pressure Issue woodenSpoon Plumbing 3 08-24-2011 11:36 AM
Hot Water Tank and Pressure Help tbakbradley Plumbing 2 01-17-2011 10:25 AM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 07:04 AM
Installing Sprinklers appear to have caused Water Pressure to DRASTICALLY increase geminigirl Plumbing 3 11-12-2009 01:04 PM
