Old 11-13-2012, 12:01 AM   #1
Low water pressure (hot water only) - temp fix when I shut off water supply to tank
Hey all - new the the forum. Was reading about low water pressure for hot water and lots of folks recommended draining out the tank. I did this a few times and did find quite a bit of small rocks/debris.
That said, after shutting off the water supply to the tank and turning it back on, it seems to correct the water pressure issue for hot water. A few days later the dreaded low pressure comes back. When I cycle the water tank again (ie, turn off the water supply to the water tank for a few minutes and turn it back on), I get pressure again for hot water.
Any thoughts on what the issue is and what steps I should take to correct the root issue?
Thanks in advance.
skilletrx is offline   Reply With Quote
Old 11-13-2012, 12:14 AM   #2
Old steel pipes?
Old 11-14-2012, 11:57 PM   #3
no steel pipes here i think its copper. anything I should look for or look into?
Old 11-15-2012, 07:22 AM   #4
You might have a build up of small particles/sediment from your flushing that have worked their way up to the fixture valve body.
Take it apart and clean it out.
bob22 is offline   Reply With Quote
Old 11-15-2012, 07:55 AM   #5
Sometimes there are check valves at the hot water tank inlet and outlet, intended to prevent eddy currents in the water from losing heat in the piping just above the tank. These could malfunction or become clogged with sediment. Some folks don't install them, but removing them is not that simple.
These check valves are not readily identifiable; if present they are incorporated into the first short pipe segments (nipples) screwed into the tank.
Turn off the water heater heat before draining any significant amount of water from the heater, and have a hot water faucet gushing water upstairs before turning the heat back on.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
The Following User Says Thank You to AllanJ For This Useful Post:
bob22 (11-15-2012)
Old 11-15-2012, 08:37 AM   #6
Is the low pressure at all fixtures?
Tags
hot water heater, hot water pressure
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 01:47 AM
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 01:05 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
