Low Water Pressure On Hot Side - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-27-2011, 12:07 PM   #1
Low water pressure on hot side
I have a two handle kitchen faucet. The hot side has low pressure. It was fine before I change the faucet.
dogloverfolks is offline   Reply With Quote
Old 11-27-2011, 12:48 PM   #2
Particles can get into a faucet and block the flow.
Disconnect the hot side at the valve under it.
Place a bucket under the valve going into the wall. Place your hand over the top (where water will squirt up) - to make the water go into the bucket. Then turn the valve on briefly to flush the line.
Next with the bucket under the disconnected hot water line, turn on the hot and cold on the kitchen faucet, then place your hand over the faucet spout. This will cause the cold water to go backwards out the hot water side and into the bucket - along with any particles which were clogging it.
This is called backflushing.
Reconnect hot side. Should now work better.
Billy_Bob is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Hot Water Tank and Pressure Help tbakbradley Plumbing 2 01-17-2011 09:25 AM
no hot water pressure in sink, but plenty in tub Turtle learner Plumbing 5 10-20-2010 07:45 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
