Low Water Pressure - Copper Pipes To Blame? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-22-2013, 06:13 PM   #1
Low water pressure - copper pipes to blame?
We have an older home, but it was mostly re-piped back in the 1980's using copper pipe except in a couple areas which still use galvanized pipe. One of the old areas is the short section that goes through the foundation and supplies the whole house.
We have poor water flow/pressure all around.
I suspect that if we re-pipe just the galvanized sections with copper or PEX of the right sizes, we just might fix the problem. In other words, as far as I know, copper pipes are not susceptible to corrosion and scale buildup inside.
Anyone have experience with flow problems resulting from copper pipe? How much chance is there that there is restricted flow in the copper sections?
Thanks,
John in Kent, WA.
jc_muir is offline   Reply With Quote
Old 01-22-2013, 06:18 PM   #2
Rewards Points: 12,808
Far more likly it's the old steel pipes causing the problum. They rust out and close up from the inside.
Is there 3/4" main runs?
What happens to copper on the inside depends on what minerals are in the water. There far more likly to leak then plug up.
Old 01-22-2013, 06:26 PM   #3
Rewards Points: 22
I would suspect the very same thing. Not impossible, but not nearly as likely that you have any problems with the copper.
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Noisy pipes that is getting worse and water pressure that is odd to say the least! RallenK Plumbing 2 10-14-2009 11:07 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
fittings and pipes sizes.. effect on pressure? cgerikh Plumbing 3 05-19-2008 11:37 AM
