Low Water Pressure Caused By Vent Pipe??? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2014, 09:06 PM   #1
Low water pressure caused by vent pipe???
A couple of weeks ago, I contacted a local plumber in town because we had an awful sewer smell coming up through our drain in our kitchen. He recommended extending our vent pipe that vents through our roof. With his recommendation, I bought 2 feet of 3" PVC piping and a coupling to add to the existing vent pipe. I also slid a insulation sleeve over the top of the new pipe. Well this cured the smell. My wife is happy.
Now I have a new issue. Since we extended our vent pipe outside, our water pressure has decreased. Our showers still work, but the water pressure is much lower. It takes a long time for the water to fill in the toilet after you flush it. When using the kitchen sink, we have good water pressure for a little while, but then fades.
Could the extended vent pipe cause us to have low water pressure now? If so, should I cut it shorter or take it off entirely? I could try removing it first to see if that helps the issue. I am at a loss here. Please help.
jlapl169 is offline   Reply With Quote
Old 02-19-2014, 09:41 PM   #2
Civil Engineer
Rewards Points: 4,766
Unless you did something to your water supply, a vent pipe should have nothing to do with water pressure.
Old 02-19-2014, 10:03 PM   #3
Rewards Points: 13,694
Two completely different issues.
(Why would you insulate a pipe that only has sewer gas in it?)
Are you on city or well water?
Got a water filter or water softener?
Is it both hot and cold water?
Tags
low , pressure , smell , vent , water
well pressure switch NJ Lady Plumbing 32 12-16-2013 03:48 PM
Water leaking from vent pipe die_of_ennui Plumbing 3 03-25-2010 08:11 AM
Installing Sprinklers appear to have caused Water Pressure to DRASTICALLY increase geminigirl Plumbing 3 11-12-2009 12:04 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
