Old 05-28-2008, 04:02 PM   #1
Unhappy Low Water Pressure
There seems to be a reduced water pressure when I fill the tub. It takes forever to fill it up. The pressure to all the other faucets, outdoor faucets, and shower is good including the sink in the same bathroom where the tub is. The tub is second to last along the hot water supply line.
Going back couple years, when I had the house inspected, the inspector told me that the tub wasn’t getting any hot water at all and documented that. The previous owner knew exactly what to do and corrected the problem. On the settlement day when I asked what he did, he said that there was some sediment in the water line and explained how to corrected it. Now that time had gone by, I don’t remember exactly what he said. If there is any sediment built up since then which I believe is happening, how can I clean it out?
Another thing to mention if it helps to resolve the tub issue, the sink in the same bathroom as the tub didn’t have any hot water also. I guess the inspector overlooked that. In addition, the shut off values didn’t turn at all. I replaced the values. Upon turning the hot water on, nothing came out. There was cold water coming out. I then, replaced the faucet. The water was dirty for a bit when I turned on the hot water and then cleared out. There was also hot water too. Cold water was fine. The hot and cold water from that faucet which is the last in the hot water supply line been working fine since.
I am assuming there is some sediment in the water supply line clogging the tub faucet and/or the spout which slows the pressure down. As I asked above, how can I clean that out?
By the way, the water is supplied from a well.
I appreciate any inputs. Thanks.
Eagle2 is offline   Reply With Quote
Old 05-28-2008, 04:35 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Is the valve on the wall and what brand is it?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 05-28-2008, 04:44 PM   #3
Yes, the value is on the wall and the brand is Delta. It is a single value for both hot and cold water.
Old 05-28-2008, 04:49 PM   #4
Journeyman Plumber
Turn the water off to house 1st, take the stem/control valve apart, and you will see rubber seats and springs beneath, remove these, with this apart, have someone turn the water on to house and let the lines flush clean, reassembly and test, that's how I would proceed.
Old 05-28-2008, 05:11 PM   #5
Thanks! I will do that tonight and see how it turns out.
Thanks again
Old 05-29-2008, 12:29 AM   #6
Doing it myself
Were you able to see what was clogging the valves for your sink? Do you have galvanized pipe anywhere in your water system?
4th Period Plumbing Apprentice
More On This Topic
Hi I'm Lauren and I'm here on behalf of Expert Village and I'm here to show you proper hand washing techniques. So the first step to washing your hands is to have a towel, paper towel, a sink and antibacterial soap. First thing first, so you enter your... Read More »
Hi I'm Lauren and I'm here on behalf of Expert Village and I'm here to show you proper hand washing techniques. So first step to washing your hands is to have a towel, paper towels, a sink and antibacterial soap. First things first so you inter your sink... Read More »
So, we see from back there that the pipe that comes from the water tank, from the rainwater tank, comes in here and then goes into this little pump. And this little pump has a pressure tank in here so that the pressure is always there. Because what we... Read More »
You can easily install a water filter under your sink to clean the water before it leaves a special water faucet. These under sink water filters check for a large variety of harmful contaminates found in tap water, making the under sink water filters... Read More »
Baby Bath Safety Tips
Baby Bath Safety Tips by Expert Village
Hi I'm Liz Hood on behalf of Expert Village and I'm talking to you about how to give your baby a bath and in this segment I'm going to go over safety tips to make sure your baby is absolutely safe at all times while you are giving him a bath, he or she... Read More »
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 01:19 PM
Help - Very Low Hot Water Pressure Renoguy Plumbing 4 04-16-2008 02:27 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 11:04 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 10:05 AM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 08:55 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
