Low Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2013, 06:31 PM   #1
Low water pressure
Cana bad hot water tank cause low water pressure?
electricbridge is offline   Reply With Quote
Old 01-14-2013, 06:36 PM   #2
Rewards Points: 13,950
Just a little more detail would sure help. This is not Google.
Is all the pressure low on both hot and cold water.
Is it all the taps.
What type plumbing do you have?
Any resent plumbing work been done?
City or well water?
Old 01-14-2013, 06:38 PM   #3
Water Treatment
Rewards Points: 900
Define bad water heater?
If the dip tube is plugged or if there is some thing plugging the in of it yes then there could be a low pressure on the hot side at the sinks.
Akpsdvan is offline   Reply With Quote
Old 01-14-2013, 06:58 PM   #4
Low water pressure
I have my answer . First of all it city regulated . Second pressure low throughout. Third is the system varies . Some copper some pex , some galvanized . And yes it's been worked on several times . The house was built in 1936 . Signing out . A MAN WITH A PLAN THANKS
Old 01-14-2013, 08:59 PM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 996
Is it all the taps.
City or well water?
Joe!! HOW Dare you ask for more details
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-14-2013, 09:11 PM   #6
i would guess that its galvanized. everytime you replace part of a galvanized system you loosen deposits in the old pipes. these deposits clog valves and stem and strainers. have you cleaned the aerators on the faucets to see if they are clogged? some shower heads have restrictors in them that it doesn't take much to clog the small holes in them. is the main line coming in galvanized?. pictures of the main line and other piping might help.
Hot water pressure low (pictures) bluefoxicy Plumbing 4 12-11-2012 07:45 PM
Low water pressure (hot water only) - temp fix when I shut off water supply to tank skilletrx Plumbing 5 11-15-2012 07:37 AM
Check valve gimaarob Plumbing 13 10-27-2011 10:13 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
