Old 09-04-2012, 08:55 PM   #1
Low Water Pressure
Once I turn on a facuet, the pumps starts immediately and the water pressure drops
hbellamy is offline   Reply With Quote
Old 09-04-2012, 09:01 PM   #2
Low Water Pressure
More than likely your tank needs to be pressurized, with air.
Old 09-04-2012, 09:07 PM   #3
Low Water Pressure
Or the bladder has burst.
Look at the brand name on the tank and go on there web site. It will give you dirrections on how to check it, what the pressure needs to be.
Old 09-04-2012, 10:13 PM   #4
Low Water Pressure
problem is in holding tank.. as mentioned..ruptured bladder..or water logged tank...
Check valve gimaarob Plumbing 13 10-27-2011 11:13 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 05:23 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
