Low Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-25-2012, 06:53 PM   #1
Unhappy
Low Water Pressure
We recently had our master br remodeled. Our shower water pressure used to be very good. Since the remodeling, the water pressure for the shower is terrible. Someone told me removing the "resistor" piece that mixes the hot and cold water for the single handle fixture would fix the water pressure problem. How does one go about doing that? I'm pretty handy, but I'm not even sure what I'm looking for. Any insight would be greatly appreciated.
Thanks!
Brian1234
brian1234 is offline   Reply With Quote
Old 02-25-2012, 08:05 PM   #2
Rewards Points: 582
remove shower head look for 2.5 gal flow restrictor...remove restrictor,,,,reinstall head and try it again
Old 02-26-2012, 04:25 PM   #3
Low Water Pressure
Really. That's it? Just curious, what if that doesn't improve the water pressure? Does that mean the new piping was installed incorrectly and/or something is blocking the pipes?
I'll let you know how it goes.
Thanks!
Old 02-26-2012, 04:29 PM   #4
Rewards Points: 582
Thanks!
could have junk in the cartridge may need to be flushed out...
Check valve gimaarob Plumbing 13 10-27-2011 11:13 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 05:23 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
