Old 02-20-2012, 01:13 PM   #1
low water pressure
I have a well with a jet pump in the house. I recently changed both the pump and the pressure tank. Since then the pressure runs between 15 35 psi . I would like to have the psi to stay between 30 to 50. When I try increasing the pressure on the pump it is Maxed out at 38 psi and then the pump just keeps running. What do I do next?
todd p. is offline   Reply With Quote
Old 02-20-2012, 01:54 PM   #2
low water pressure
It sound like your pump might not be big enough. If you set the pressure switch to 50 psi and all the pump will produce it will run continually trying to get to 50. Did the old pump maintain 50 psi? Is the new one the same size.
M Engineer is offline   Reply With Quote
Old 02-20-2012, 06:46 PM   #3
low water pressure
did you replace pressure switch if so did you buy the right one it usually says on box and on cover of switch on inside which has a 20 # difference then you need to set air in bladder correctly should have chart with new tank
here is good sizing reference link for sizing
http://www.watersystemscouncil.org/V...Tank_FINAL.pdf
jaydevries is offline   Reply With Quote
Check valve gimaarob Plumbing 13 10-27-2011 11:13 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 05:23 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
