Old 02-04-2013, 01:50 PM   #1
low water preasue with 5 connected sinks
Hello my g/f owns a salon and has 5 sinks that are all connected. The first and second have low water preasure and the other 3 are somewaht low also just not as bad. Any help would be greatly appreciated
jayjensen is offline   Reply With Quote
Old 02-04-2013, 02:24 PM   #2
MarginallyQualified
The first and second have low water pressure
and the other 3 are somewhat low also just not as bad.
"low" and "somewhat" are vague terms.
Does any other sink there have "good" water pressure?
How about at the business next door?
How many valves are there on the pipe en route to the sinks?
Has anyone cleaned the outlet strainer?
Give us something to work with.
TarheelTerp is online now   Reply With Quote
Old 02-04-2013, 05:10 PM   #3
Thank you for responding. A little more info here in that all 3 seem to have low [reasure but especially the middle one and especially with hot water. All 3 seem to need new hoses as they splatter water. I will have to check on valves but does this give anyone an idea tyvm
Old 02-04-2013, 05:23 PM   #4
A salon like that should have had 3/4" main lines ran so they would have the same pressure.
You could have 100 PSI pressure but if the lines are to small the water can not get the fast enough to maintain flow.
Old 02-04-2013, 06:05 PM   #5
If you have 100 psi then your fixture will be blowing a part. They run 3/4 for the volume. A 1/2 line or a /4 line will have the same pressure. What you need to do is check the incoming pressure at the meter. Must see if they got a pressure reducing valve. If they do then you can turn it up. Mite be old Water line coming in and clogged up. But start will checking the pressure.
65 to 80 psi should be good.
handyman21 is offline   Reply With Quote
Old 02-04-2013, 06:08 PM   #6
Read agin, never said he needed 100 PSI.
Old 02-04-2013, 06:35 PM   #7
Sorry you could have 100psi
Old 02-04-2013, 07:29 PM   #8
Master Plumber
Javiles's Avatar
Are they belvedere shampoo sinks or commercial shampoo sinks ??
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 01:47 AM
Sandy water plugged toilets and sinks Felix520 Plumbing 3 11-06-2011 10:37 AM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 10:47 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
