Low Water Flow To Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-15-2012, 07:53 AM   #1
Unhappy
Low water flow to tub
We shock treated our water well and after running fresh water out we began to use our tub again but the water flow from it is poor. There might be debris of some sort in the plumbing from stirring up the well or some part of the shock treatment process, but we have no idea how to loosen it up or deal with it. The water flow from the 2 tubs is so slow, we can barely get a shower out of them. The tubs are both 1 - peice units.
cbowick is offline   Reply With Quote
Old 08-15-2012, 10:30 AM   #2
Rewards Points: 14,026
#1 Post a picture of the tub valve from inside the tub so we can get an idea of what brand you have.
The valves going to have to come apart to be clean. Most likly if it's a newer valve the scald valve is stuck because of trash.
Tags
tub low water flow
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 02:35 PM
Hot Water Flow kcirtap23 Plumbing 1 02-10-2012 04:11 PM
Tub hot water does not Flow at all (details enclosed) lisaz Plumbing 7 12-17-2008 08:16 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
