Low Water Flow Bathtub Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-05-2009, 05:09 PM   #1
Low water flow bathtub faucet
Water flow at bathtub faucet has been getting weak, changed the cartridge today and no difference. Water pressure is fine at the bathroom sink, and the toilet.
Oh my faucet is a delta 1400 series. Is there another valve or something inline? Removed cartidge and turned on water and it seemed fine. This does not make any sense, I dont understand how you could get any water through those small holes. Thanks in advance
osirus065 is offline   Reply With Quote
Old 09-06-2009, 07:39 AM   #2
Whisky Tango Foxtrot all these views and no answer? bump
Old 09-07-2009, 11:49 AM   #3
Is it only weak at the shower head or also the spout?
plumber Jim is offline   Reply With Quote
Old 09-07-2009, 11:51 AM   #4
If the flow is bad at both shower head and spout you can replace the cartridge and see if that helps. the balancing spool in the cartridge could be bad.
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 05:10 AM
water flow problem copwk Plumbing 2 07-27-2008 07:12 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
Air Lock in hot water line? tqwood Plumbing 3 03-15-2008 11:26 PM
Help! hot water won't stop running despite faucet changes. nodak_luke Plumbing 4 12-14-2007 05:38 PM
