Low Water Flow - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2011, 11:17 AM   #1
WRD
Low water flow
I have a Pricepfister 531 series pull out faucet with very low out put.
How can I get more water out. it has the same flow from hot or cold.
I took off the spray head and there is a very low flow also.
Bill
San Antonio, TX
WRD is offline   Reply With Quote
Old 02-04-2011, 01:44 PM   #2
Rewards Points: 352
Pretty good chance your pull out hose is full of little pieces of minerals, or deteriorating dip tube.
First disconnect supply lines from the stop valves and check for flow at the valve. That will tell you if the problem is before or after the valve
plumberinlaw is offline   Reply With Quote
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Tub hot water does not Flow at all (details enclosed) lisaz Plumbing 7 12-17-2008 09:16 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
Bathroom Faucet Low Water Flow domesticproperties Plumbing 2 07-27-2008 07:01 PM
