Low Pressure Water To Mix Into High Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-22-2010, 12:18 AM   #1
low pressure water to mix into high pressure
Have a tank with low pressure water coming out and want to mix it into the high pressure mains water stream what is the best way to do this.
iancan is offline   Reply With Quote
Old 03-22-2010, 10:09 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,612
Ayuh,... You'll have to explain what you're wanting to do, Better than that...
With what little you state, the Hi-pressure will move TO the low pressure...
Simple Physics...
Bondo is online now   Reply With Quote
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
Water pressure problem bmoss1973 Plumbing 8 02-22-2009 05:08 PM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 05:10 AM
Water pressure and temperature billvasko Plumbing 9 06-02-2008 09:23 AM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
