Low Pressure From Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-17-2007, 10:13 PM   #1
Unhappy
Low Pressure from Shower
I had to replace my water heater a few days ago. After installation, my shower would barely trickle out. I am on a well with no filtering system. I replaced the old shower head and after installing the new one I still didn't have very good water pressure. I suspect the plumber may have messed up my Delta 1 piece handle by overturning it when he was testing after turning the water back on. What should I look for when removing the Delta handle? I'm thinking that it has gotten out of line or something. Please advise.
Thanks!
ronniecr is offline   Reply With Quote
Old 03-18-2007, 03:41 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Call the plumber back out, if he touched the fixture while there, he should make sure it operates properly before he left.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 10:33 AM
Shower Pressure Problem rob1970 Plumbing 18 03-10-2007 10:41 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
Pressure Compensating Shower Valves MikeinBurien Plumbing 4 12-21-2005 10:13 PM
New Water Heater, worse pressure Repoman75 Plumbing 6 04-15-2005 11:30 PM
