Low Pressure From Moen Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-07-2011, 10:29 PM   #1
Low Pressure from Moen faucet
I can not get any pressure from my new Meon faucet. I get a trickle of water but NO pressure. This is a Moen single lever, and the sprayer retracts back into the Handle unit (one hole in counter). Only dripped from factory, found machine milling shavings in sprayer filter (twice) got new cartridge, and still no pressure. Called Moen they sent new faucet set, installed it same problem. Moen sending another new cartridge saying thats all that can be wrong. Water supply NOT the issue, new 1/2 lines installed and will spray sink base easily. Any like problems with no pressure?
tsperry is offline   Reply With Quote
Old 12-08-2011, 05:11 AM   #2
DIY staff
Rewards Points: 7,174
Post a picture from under the sink---
Have you opened the shut offs when the cartridge was removed to ensure that the shut offs are working?
A common cause of the problem you describe is crud in the back flow preventer --
this is located where the hose for the wand attaches to the valve body---
Get a diagram of your faucet--you will find it----some times you need to hold a bucket under the valve body and turn on the faucet---the little part will blast right out into the bucket---
tsperry (12-08-2011)
Kitchen faucet, low hot water pressure carlas Plumbing 2 12-02-2011 09:07 AM
New Faucet not running with full pressure teamcurtis Plumbing 3 07-13-2011 03:17 PM
Pressure drop after replacing faucet seat plumbing_noob Plumbing 5 10-25-2010 09:14 AM
Very low pressure on bathtub faucet/ showerhead Mermarisa Plumbing 7 10-10-2009 11:47 PM
Moen 3 knob faucet repair? blue82001 Plumbing 3 06-16-2006 11:32 AM
