Low Pressure After Power Outage - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-06-2011, 11:20 AM   #1
Low pressure after power outage
Please excuse my newbieness with this stuff and my lack of correct terminology.
We lost power during the middle of the night and not knowing it, I went in to use the bathroom, flushed, and walked out only to find no power.
Now my water pressure is almost next to nothing and the power has come back on.
We are on a well system and we have a tank that that is at 55psi at this moment. I followed these instructions and flipped the switch next to the tank but we don't seem to be getting pressure back.
Any suggestions?
cornick is offline   Reply With Quote
Old 11-06-2011, 11:40 AM   #2
DIY staff
Rewards Points: 7,174
First thing to do---see if both legs of the power are on.
Your house has two different 110 lines coming in--when combined they are used to power 220 circuits.
If one has quit --you might have lights but no proper power for the 220 fixtures.
Old 11-06-2011, 11:58 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well pump may not be working properly do to low power. Possible blown circuit breaker or fuse. Well water pressure tanks require time to build and pressurize after being depleted.
Old 11-06-2011, 12:01 PM   #4
Everything else looks good. I did reset the breaker just to be sure.
I checked the pressure again, and read it wrong the first time, it's at like 48.
I actually have zero water at this point as my son just flushed and no water came up. Faucets aren't spewing liquid gold either.
Old 11-06-2011, 12:09 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Your water well may have a circuit breaker or fuse in more than one location. Check them all.
Old 11-06-2011, 12:40 PM   #6
So the switch, which was filthy and I couldn't see the labels, had 3 settings. Auto, Start, and Off.
When moving the switch from Auto to Off you could hear it click but that's it. If I manually held the switch at Start it would start to run. I held the switch there for about 10 seconds and you could hear the water going through the house. I let go of the switch and it falls to the Auto position and it continued to run.
Almost seems like a safety feature that something can't just bump it, it needs to be held to manually make it run.
But either way, I've got water!
Thanks everyone for the replies and your time, I appreciate it.
Old 11-06-2011, 12:58 PM   #7
DIY staff
Glad to hear it----Might be a good time to stock up an some new switches----they always seem to fail at night--on a holiday --during a storm.
Old 11-06-2011, 01:49 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 858
Yes....
And now is the best time to learn how your system runs...it's much easier to troubleshoot when you know how it is supposed to work vs trying to figure out how it is supposed to work.
ddawg16 is online now   Reply With Quote
cell/email notification in the event of a power outage jorourke Electrical 14 02-06-2013 05:46 PM
Lennox A/C not working after power outage. Tri Boyer Appliances 0 08-24-2011 03:43 PM
All wiring underground, yet power outage...? PCMLR Electrical 2 10-10-2010 11:20 PM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 01:59 PM
Older air compressor wiring help lash-1295 Electrical 91 12-23-2009 01:46 PM
