-   -   low pressure after hot water heater replacement (http://www.diychatroom.com/f7/low-pressure-after-hot-water-heater-replacement-106937/)
tuffluck 06-07-2011 03:10 PM
our hot water heater leaked and ruined our floors about 2 months ago. it was replaced and all was well except the kitchen sink (which is about 8 feet away from the hot water heater unit) now has extremely low water pressure. i would say it lost about 70% of its water pressure immediately following the hot water heater breaking. also next to the kitchen sink is the dishwasher, which has been increasingly showing bits of soap in the glasses after its cycles. that leads me to believe the dishwasher also is not getting enough water pressure. the sink does not have hot and cold valves, just one valve that you rotate to choose your water temperature.
all the other faucets/tubs in the house get exactly the same amount of water pressure as before the hot water heater broke. the kitchen pressure is so bad it is almost unusable for most things except washing your hands.
also sort of related but not really, the kitchen sink has always had really funny tasting water. it doesn't taste funny out of any other faucet, but it tastes so strange coming from the sink that we have to use a brita filter for the water. there are also small particles coming out of the water we don't see in the other faucets. i wonder if the combination of those two things means something is wrong with the actual faucet and/or pipes.
anyone have any suggestions or places to look/check? thanks.
Durt Ferguson 06-07-2011 03:19 PM
It could be possible that something got forced into the line during the replacement process (solder, mineral, piece of rubber, etc). Or whatever was producing the taste/particles became dislodged or something. Don't know how one would go about fixing something like that, though. Just a thought.
tuffluck 06-07-2011 03:49 PM
too bad you can't put draino through a faucet pipe?
mustangmike3789 06-07-2011 04:11 PM
pull the aerator off of the faucet and run the hot water to clean any debris out of the line. your water filter and dish washer probably need to be cleaned too. this is not uncommon after changing a water heater.
tuffluck 06-07-2011 04:14 PM
the water filter...where would i find that? did you mean the actual dish washer or the dish washer filter (also where would i find that one too)?
