Old 03-12-2007, 12:10 PM   #1
Low Pressure
I've got old galvanized pipes throughout my house and have low water pressure, to the extent that you cannot use the kitchen sink if the shower or washing machine is running. I know that with this kind of pipe, corrosion builds up inside and they constrict and thus you get low water pressure. But I’m trying to figure out the best way to remedy this. It seems to me that a re-pipe is the way to go but is there any chance that maybe just the pipe from the shutoff needs to be replaced or something? The reason I ask is because each fixture has decent pressure on its own – it’s just when you turn on two fixtures on at once that it drops.
I just don’t want to go ahead with a whole re-pipe if something less might get the job done.
Thanks!
digthisbigcrux is offline   Reply With Quote
Old 03-12-2007, 12:17 PM   #2
Low Pressure
Do you lose pressure only at the kitchen sink?
What size pipe do you have?
redline is offline   Reply With Quote
Old 03-12-2007, 12:49 PM   #3
Low Pressure
We lose it everywhere when you turn another fixture on.
Pipe looks like it's about two inches.
Old 03-12-2007, 03:12 PM   #4
Low Pressure
Are you sure you are looking at the water supply piping? I have never seen anything larger than 1" piping in residential use. 2" or even 1-1/2" sounds like drainlines.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 03-12-2007, 03:18 PM   #5
Low Pressure
I am looking at the supply but it probably is 1 inch. Like most men, I tend to over-estimate size in inches.
Old 03-12-2007, 03:21 PM   #6
Low Pressure
Galvanized pipe served it's purpose for years but when it goes bad, it's over. If you remove a piece of that 1" pipe, it will probably have a hole smaller than a pencil in it. I think you are going to be repiping. Sorry.
Old 03-12-2007, 10:02 PM   #7
Journeyman Plumber
Ron The Plumber's Avatar
Low Pressure
Yep time to repipe, go with pex pipeing if allowed in the area.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Pressure Tank Question? cruzplanner Plumbing 3 02-11-2009 12:11 PM
Water pressure? What water pressure? mnp13 Plumbing 9 05-03-2007 03:32 PM
High pressure bjr23 Plumbing 1 03-27-2007 08:24 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 10:04 PM
