Low Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-31-2012, 11:08 AM   #1
low pressure
Hey,
I live in a 2 story home and my water pressure is at best terrible on are 2nd floor bath, the sink in the Bath is effected as well toilet also,( Low Pressure). I have City water and when they checked it at the City side it was 47lbs, I did a pressure test on the 2nd story Bath and it was 26 lbs. the rest of the House is fine. My Qustion is Could I put in a Pressure tank you see in home with wells? I also would like to redo the water line in the House as well. any thoughts
Dave
splinter2 is offline   Reply With Quote
Old 07-31-2012, 12:54 PM   #2
Rewards Points: 13,300
Sounds like someone may have ran a 1/2" instead of the needed 3/4 main supply line to the second floor.
Old 07-31-2012, 01:19 PM   #3
Pressure
Joe,
Never even thought to check that? Let me go check and repost. Thanks
Splinter2
Old 07-31-2012, 10:00 PM   #4
Rewards Points: 582
if the city pressure is only 47 lbs thats your problem....thats low..average is around 65-80lbs.... even if your line is only 1/2" it will still show the city pressure....it would however restrict volume flow...
Old 08-01-2012, 06:46 AM   #5
Is it old steel plumbing?
Pressure washer no pressure: and deadly WAND disconnect a_gunslinger Tools 6 07-21-2012 01:06 PM
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 10:03 PM
low water pressure from well pump supply dolfan13jmb Plumbing 4 03-03-2011 02:28 PM
Hydronic boiler pressure question. RickInMissouri HVAC 1 01-23-2010 05:57 AM
