Low Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2012, 11:47 PM   #1
Low Pressure
I live in a 2 Story home, with a 1/2 Basement so I guess its 3 storys, But are main bathroom in on the 3rd floor, and we have low Pressure and it takes forever to get Hot water to shower and sink, Once I get it, Its fine Just takes like 2 to 3 minutes. Pressure is Decent Just think it could be Better. What are my Options, If any?
Thank you for your time
Dave
worsley22 is offline   Reply With Quote
Old 02-02-2012, 11:52 PM   #2
Rewards Points: 582
Dave
1st the distance is why you have to wait 2-3 minutes..next is pressure...do you have a pressure regulator installed by meter? copper, or galvanized????these help us to determine issue your having as well as pictures...ben
Old 02-03-2012, 09:09 AM   #3
biggles's Avatar
if nothing else is being used you should have the same pressure that the nearest sink has...or the pressure on the hose when you connect it to the HWH drain cock..might have a retriction on the hot water out nippleor Arod
Old 02-03-2012, 06:44 PM   #4
how
Rewards Points: 1,070
Water guages that can screw onto a laundry tap or HWT drain are cheap and will tell you if you have a real home water pressure issue or if it is really a water flow problem.
Is it just the Hot water or is the cold equally weak? Is the house water valve really opened up all the way? Have you a home pressure reducing valve with a dirty entry screen? Type of house piping and are any of the original house galv fittings still in place? Slime plugging the HWT inlet or exit flapper valves?
how is online now   Reply With Quote
Old 02-03-2012, 06:58 PM   #5
GC/Master Plumber/Mech
Rewards Points: 560
Remove the faucet airator and see if you have better pressure/volume
With the shower remove the shower head and see if the head is restricted.
Over time they can collect and scale up causing all kinds of problems
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
The Following 2 Users Say Thank You to Plumber101 For This Useful Post:
how (02-03-2012), plummen (02-03-2012)
Boiler pressure troubles jduffett HVAC 2 12-12-2010 08:15 AM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 07:04 AM
Older air compressor wiring help lash-1295 Electrical 91 12-23-2009 01:46 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 10:50 PM
