Low Point In Water Supply Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-01-2011, 01:59 PM   #1
Rewards Points: 201
Low point in water supply lines
Iím replacing the old copper water lines in a section of my basement, using Pex-A, and re-connecting to the old copper lines as they go above the garage (which is level with the basement). I want to run the pex perpendicular through the joists, instead of below them, where the old copper now runs, but it occurred to me that this will make the old copper lines above the garage a ďlow pointĒ in the supply lines, making it impossible to drain them without cutting into them. Itís only a 2 inch difference in height. I flipped through the IRC and didnít see any regulation on this issue, though every house Iíve lived in, the supply lines were totally drainable through a faucet or spigot at the lowest point.
Anyone know if this is in fact prohibited by Code? Or whether it is a bad idea otherwise?
As far as I can see, the only drawback would be a face full of water if I ever had to work on the lines over the garage.
And again, Iím talking about the supply lines, not the drains.
Thanks.
dave11 is offline   Reply With Quote
Old 02-01-2011, 03:25 PM   #2
Experienced
Jackofall1's Avatar
Pittsburg, garage, water lines..........ICE? Specially if you can't drain them.
Old 02-01-2011, 08:06 PM   #3
Rewards Points: 201
The same copper lines have been there above the garage for 60 years, and haven't frozen yet. I don't know many people who drain their plumbing for freezing weather.
Old 02-01-2011, 08:13 PM   #4
Experienced
Jackofall1's Avatar
Nope you are right, but if you do need to drain and it is freezing weather how will you do it.
Just making a point.
So you have lines in your garage that are 60 year old copper, really, I thought most builds back then were with galvanized, learn something new every day.
Mark
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
correct size pipe for water lines jce Plumbing 2 04-11-2010 09:23 PM
water supply layout wglord Plumbing 1 07-13-2009 01:07 PM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 02:36 PM
