Low Or No Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-10-2010, 11:38 AM   #1
Low or no pressure
Yes I've just had a multiple head shower with the 6 bodysprays,a 10"rain head, the hand shower and the regular shower head installed into my bathroom.The house basically is a new construction build. The problem I'm having is that the shower was working fine all the sprayers,heads and hand wand was working perfectly fine. The water pressure was fantastic,until. We got moved in power turned on hot water heater going and I went to test the temperature of the water in that shower. The water got hot all but for 10 seconds a the water pressure took a complete nose dive to nothing. Every other faucet in the whole house is working perfectly fine. ?????????? Why is this one giving me the problem. Thanks in advance
acediggum is offline   Reply With Quote
Old 12-10-2010, 03:39 PM   #2
My first guess is that the pressure balance spool is stuck. Or there is debris caught in the flow restrictors. To help you correct it I need more info. Brand and model of faucet. Or a good picture of it all would help too.
Work4living is offline   Reply With Quote
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 06:04 AM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 12:59 PM
Older air compressor wiring help lash-1295 Electrical 91 12-23-2009 12:46 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 09:50 PM
