Old 09-03-2012, 06:19 PM   #1
Low hot water temp. from gas water heater in hot weather.
My 40 gallon gas water heater is not heating water well in hot weather.It gets hotter in evening as temps. drop.sometimes in the morning it takes awhile to get hot water even at faucet closest to heater.I try to drain tank twice a year.themostat set to about 115-120 degrees.Thanks for yor help.Rob
RNash is offline   Reply With Quote
Old 09-03-2012, 06:34 PM   #2
Bombastic Idiot
notmrjohn's Avatar
How much insulation is on that tank? Is it in place that is air conditioned during hot season, heated during cold season? How long is run to nearest faucet, pipes in AC'd heated area? How long is "a while"? I don't think AC would have that much effect on heater, it would just come on more often, but...
Sure you don't have your thermometer upside down and are confusing hot weather with cold?
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Best practices for Water Heater install? simanco Plumbing 4 08-23-2012 12:36 AM
Tankless hot water heater during winter when water shut off jdabs Plumbing 3 07-10-2012 01:50 AM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
