Low Hot Water Pressure In Upstairs Sink But Not Upstairs Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2011, 02:47 PM   #1
Rewards Points: 12
Low hot water pressure in upstairs sink but not upstairs shower
Within the last week the hot water in our upstairs bathroom sink suddenly lost pressure. When you first turn it on after being off for a while it flows strong but as the water heats up the flow slows down singificantly however in the bathtub in the same bathroom there is no problem. Oh and the sink has separate hot and cold controls rather than a single control and the cold water works just fine. Any idea what would be causing this. I would have thought its related to a pressure problem to the hot water line that comes upstairs and feeds the sink and tub but since the hot works fine on the tubs faucet this couldn't be the case could it? Only other thing I thought was maybe its the faucet control itself but then why would there be full pressure briefly until the hot water side heats up?
Thanks in advance,
Adam
amn70 is offline   Reply With Quote
Old 05-12-2011, 10:34 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You may have some floating debris (piece of interior pipe scale or part of a rubber washer or o-ring, etc.) in the hot side of the dual-handle faucet.
Turn off the water, dismantle and remove the hot side faucet body, cover it with a towel and have someone turn the water on very briefly to flush it out.
Check the washer and o-rings on the faucet body while you have it out. Replace if necessary.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
no hot water pressure in sink, but plenty in tub Turtle learner Plumbing 5 10-20-2010 07:45 PM
I have lost water pressure in my shower kiddd66 Plumbing 6 10-15-2010 07:34 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
water pressure in shower issues sflamedic Plumbing 8 04-07-2009 01:55 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
