Low Hot Water Pressure In Two Faucets - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-30-2011, 10:27 AM   #1
Low hot water pressure in two faucets
I have low pressure in kitchen and master bathroom shower faucets for hot water. All other faucets have excellent pressure for hot. Any ideas what could be causing this and how to correct?
djtwins2008 is offline   Reply With Quote
Old 05-30-2011, 10:33 AM   #2
Have you had any work done on the plumbing recently? Do these lines share the same feed? Is there a there a shutoff valve, or valves, for these lines that may only be partially open?
VIPlumber is offline   Reply With Quote
Old 05-30-2011, 10:54 AM   #3
waterman1971's Avatar
Rewards Points: 154
Tuberculation perhaps.
waterman1971 is offline   Reply With Quote
Old 05-30-2011, 12:53 PM   #4
No shut off for these two only.
Would the pressure only be affected on hot water if tuberculation was the culprit?
Cold water has excellent pressure on both faucets.
Old 05-30-2011, 02:06 PM   #5
I had to look up 'tuberculation' and basically is means build up on the inside of the pipes, from what I can tell.
It could be tuberculation but the only way I believe you could tell for sure if it is tuberculation is to cut the pipe open and look. It would be a real PITA though.
What type of piping do you have?
Tks w-man, I have a new favorite word to sling around.
Old 05-30-2011, 02:20 PM   #6
Rewards Points: 154
Try removing the screens and tapping LIGHTLY on the pipe to see if anything breaks loose.
Old 05-30-2011, 02:56 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 914
Wow, over 20 yrs in the trade- never heard that word. Sounds cancerous
I think I'll try it out on a homeowner. Might increase sales
Old 05-30-2011, 03:10 PM   #8
Rewards Points: 154
In my home every plumbing fixture is attached to a network of galvanized pipe.
This network exists outside of the entry point into the wall.
Each component of this network must not exceed 3" in length.
I have remove pieces and found light unable to pass through them ( note 3" max length )
Anyway at work we refer to this as tuberculation.
I have seen a 24" reduced to less than 1" in a year's time.
Old 05-30-2011, 03:11 PM   #9
Rewards Points: 154
What do y'all call it?
Old 05-30-2011, 03:19 PM   #10
Plumber
Rewards Points: 914
I call it a plugged water pipe and it smells like money to a plumber
Seriously though, I have 50 yr old galv. in my house(incl the house supply). They are pretty clear.
Old 05-30-2011, 03:20 PM   #11
Rewards Points: 154
What is your alkalinity?
Old 05-30-2011, 07:22 PM   #12
The pipes are copper. shower head in the master had residue on it when we moved in. I replaceda year ago and have no noticable buildup.
Old 05-30-2011, 08:38 PM   #13
Just call me Andrew
Rewards Points: 1,020
There is no way I am the only one that read this as "Tuberculosis".
Andrew
secutanudu is offline   Reply With Quote
low water pressure from well pump supply dolfan13jmb Plumbing 4 03-03-2011 01:28 PM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 09:16 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
