Low Hot Water Pressure In Shower Only - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-13-2011, 05:29 PM   #1
low hot water pressure in shower only
I bought a foreclosed house and do not have hot water pressure in the shower only. Today, I flushed the hot water heater and checked and cleaned the nipples on top of the tank. I took the shower head off. Since it is only the shower, is there a valve stem or something at the shower faucet where the hot and cold water mix? Thanks
klaus135 is offline   Reply With Quote
Old 11-13-2011, 06:50 PM   #2
Rewards Points: 582
if your pressure problem is only in shower then its got to be faucet....pics would help..or more details.....single control,,2-handle..3-handle.....
Old 11-13-2011, 07:21 PM   #3
Thanks for responding, Im not sure what a picture would show other than not much water coming out of the shower head. But it is a single handle. Copper pipes.
Old 11-13-2011, 07:51 PM   #4
Rewards Points: 582
ok that helps....you did say just hot ...water is .slow could be temp safty control behind handle to prevent scalding....set to low= low pressure...if pressure is low on hot and cold could have clog in faucet or shower arm ..how long did house sit before turning on water?
Old 11-13-2011, 08:01 PM   #5
house was sitting for at least a year, that i know of. i just youtubed my problem and they are showing how to replace a valve cartrage. I guess i will try that in the morning. Yeah, its just the hot water, cold has lots of pressure. When i turn it to hot, all but a very small stream of water comes out. Most of the other threads i googled talk about the hot water heater, but like you stated, it has to be the shower b/c all the other facuets are fine. thanks for responding
Old 11-13-2011, 10:11 PM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Keep in mind that they are all very different animals.
Journeyman Plumber
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
1 Week Old Shower - Water Pressure Disappeared? ClarendonCondo Plumbing 8 10-18-2009 06:41 AM
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 11:53 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 11:29 PM
Hot water pressure in the shower Randy Stuempfig Plumbing 15 01-03-2008 10:58 AM
