Low Hot Water Pressure In Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-17-2008, 07:15 PM   #1
low hot water pressure in shower
I live in a 3/2 less than 2 years old with showers and tubs in both bathrooms and 2 sinks in both bathrooms. the problem is with the shower head just on the other side of the hot water heater ( closest to the hot water heater). There cant be more than 5 feet of pipe between the shower head and the hot water heater.
The problem is I have LOW!!! hot water pressure in only this shower. All other outlets are fine. I have a well and an electric hot water heater.
Anyone have a clue?
avlivewire is offline   Reply With Quote
Old 10-17-2008, 08:23 PM   #2
Man of many hats
wrangler's Avatar
Rewards Points: 354
It might be your valve in the shower. Many valves, especialy Delta, have a hot water limiter that prevents scalding. It is a plastic piece preset by the plumber/installer that limits how hot the hot water can be mixed with the cold. If you post a pic of the handles, I might be able to guide you through the process of changing the 'high end limiter" or you could try to look up the model itself via google. This is a manufacturters limiter that allows the plumber to set the high temp limit so that children do not accidentally scald themselves. Often, it is as easy as pulling the temperature control cover off of the handle assembly, removing the screw, rotating the grooved 'limiter' to a hotter position, and then replacing the screw and 'beauty cap'. If you are unsure, see if your local hardware store has a similar valve and ask about the above procedure for your valve.
HTH
Brett
Man of many hats
wrangler is offline   Reply With Quote
Old 10-18-2008, 02:32 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
It's probably what wrangler thinks, but what kind of faucet do you have?
Brand? Single handle? Double handle?
Sometimes internal plumbing debris can partially clog one side (or both) of a faucet. The other solution is to turn your water off, dismantle the faucet, and then turn the water back on very briefly to flush it out into the tub. I have all Delta single handle faucets, and that usually works for me.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 08:07 PM
Hot water pressure in the shower Randy Stuempfig Plumbing 15 01-03-2008 09:58 AM
No Hot Water Pressure In Shower Randy Stuempfig Plumbing 6 01-02-2008 07:35 PM
