Low Hot Water Pressure In One Shower Only - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-08-2011, 11:54 PM   #16
Plumber
TheEplumber's Avatar
Rewards Points: 676
Originally Posted by hamsandwich View Post
So, I screwed the left one all the way in, which stopped all cold water from running in that faucet. In this case the cold is on the left, and the hot is on the right. Not sure if that changes anyone's thoughts on what they suspect as the issue?
Yes, I'd be fixing the screwdriver stop. Should be able to buy a kit for it. What about the hot water at the lav?
Old 12-09-2011, 12:32 AM   #17
Originally Posted by TheEplumber View Post
@ hamsandwich- ...
Oh, just for giggles- remove the aerator on the lav faucet and see if it helps the flow any.
Are you referring to the valve under the bathroom sink? I haven't touched that, but the hot water there comes out full blast.
hamsandwich is offline   Reply With Quote
Old 12-09-2011, 06:05 AM   #18
DIY staff
Rewards Points: 7,174
It is possible that the damaged valve on the right is the 'HOT'---this is a condo and back to back mixers are common--with one having the feed lines reversed--
Run the water and see which pipe is hot---right or left.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
1 Week Old Shower - Water Pressure Disappeared? ClarendonCondo Plumbing 8 10-18-2009 05:41 AM
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 10:53 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
Hot water pressure in the shower Randy Stuempfig Plumbing 15 01-03-2008 09:58 AM
