Low Hot Water Pressure In One Shower Only - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-07-2011, 12:49 PM   #1
Low hot water pressure in one shower only
Hi all, this is my first post on this forum. I do not have any plumbing experience, but I consider myself fairly handy when I need to be.
I've lived in my condo for a few years now and the front bathroom has low water pressure in the shower. It's been that way since we moved in. Every other faucet in the unit is working fine. I removed the faucet handle and faceplate to take a look. The valve body has a stop check valve on each side similar to this style http://www.cpmdelta1.com/Product%20A...ck%20Valve.jpg
The one on the left looks to be all the way out. The one on the right appears to only be about halfway out and the area that you would use a screwdriver to turn it, is stripped. So I cannot unscrew it further to see if it helps the pressure.
I called a local plumbing company as was quoted about $200 to look at it and maybe fix it. I was told it may require a replacement of the valve, which involve tearing out a large chunk of the wall. This would end up costing a fair amount of money. I don't mind spending if I have no other choice. Any suggestions on how I could look into this problem further on my own, or least ensure that I don't get hustled into expensive repairs I may not need?
hamsandwich is offline   Reply With Quote
Old 12-07-2011, 02:34 PM   #2
Rewards Points: 474
You didn't say if you took the shower head off ??? If not do it and see what kind of preasure .
del schisler is offline   Reply With Quote
Old 12-07-2011, 02:38 PM   #3
DIY staff
Rewards Points: 7,174
Have you tried all the usual things that cause low water pressure?
#1 being the shower head--Remove that and see if it works well---there is a water restricter in most of them---remove that and see if it's acceptable.
Do you have to shut down the whole building to work on that valve?
Old 12-07-2011, 02:45 PM   #4
Sorry, I guess I left out some details. I have not taken off the shower head, but the low hot water pressure is persistent out of the bath faucet and shower head. All other faucets, including the sink in that same bathroom are working properly.
Old 12-07-2011, 02:49 PM   #5
DIY staff
You are right,I think--that mini shut off is only partially open---You may have a problem that will require changing it---Post a picture of the bad Unit--someone here might know if it's rebuildable without opening up the wall---Mike---
Old 12-07-2011, 10:26 PM   #6
I've attached some pictures of the valve unit. Included are some close-ups of the stop/check that is stripped. There's just not enough there to use a screwdriver. I also tried a pair of pliers, but couldn't get a real solid grip on it and it wouldn't budge.
Low hot water pressure in one shower only-image01.jpg   Low hot water pressure in one shower only-image02.jpg   Low hot water pressure in one shower only-image03.jpg   Low hot water pressure in one shower only-image04.jpg
Old 12-08-2011, 04:53 AM   #7
DIY staff
That's a Moen--if the stops are Moen also---you should be able to re-gut that valve---bring that photo to a good old time plumbing supply house and see if they can identify it for you---
Also call Moen--technical help line---
While you are at the supply house ask for a plumbers name--they know the skilled ones from the dimwits---(ask quietly --most houses don't give out names for fear of offending the clients)-Mike-
Old 12-08-2011, 06:11 AM   #8
Rewards Points: 582
the nipple going to tub spout looks to be iron? that could be some of the problem and if shower pipe is iron,seen this a few times.check that... as far as stops go you could take valves apart remove guts put back and run like that till your ready to replace.....
Old 12-08-2011, 10:01 AM   #9
Thank you for the responses. I'm slightly hesitant to work on this myself since it is a condo building. I don't want to be responsible for any water damage to someone else's unit. It seems it would be wise for me to have a professional come do the work you guys have mentioned. What would you consider to be a fair estimate for either the gutting or full replacement? And would the full replacement require them to tear a larger hole in my wall? Thanks again for all the help.
Old 12-08-2011, 05:26 PM   #10
Rewards Points: 175
I am thinking maybe a new cartridge
Old 12-08-2011, 05:47 PM   #11
DIY staff
The little screw thingys are SHUT OFF VALVES--
One of them is damaged (the right one ) and needs repairing--
Did you even read the thread ?
Old 12-08-2011, 06:24 PM   #12
Rewards Points: 175
A cartridge is a unit which is inside of a valve and a metal pin spins in a housing allowing water to flow through and shut off. therefore in this case i am thinking that the cartridge has bound up limiting the water flow to pass by the pin.
licensed plumber and business owner for 26 years
Old 12-08-2011, 06:31 PM   #13
Rewards Points: 175
HOT IS ALWAYS ON THE LEFT
but agreed
Old 12-08-2011, 07:38 PM   #14
Plumber
TheEplumber's Avatar
Rewards Points: 664
@ hamsandwich-
I believe your problem will be in the cartridge. An easy fix for you. There are several threads here that discuss how to do it. The reason I think it's the cartridge is you mentioned low HW (not CW) pressure at both the lav and shower. So I ruled out the CW angle stop (which can be rebuilt)
If new cartridge or shower head doesn't solve the problem, then I would take a good look at the age and condition of the HW piping in the walls. They maybe full of scale, therefore restricted. Again, you mentioned low HW at two fixtures.
And yes, the wall will be opened up to replace the valve if it comes to that- and I don't think it should.
Oh, just for giggles- remove the aerator on the lav faucet and see if it helps the flow any.
Old 12-08-2011, 11:50 PM   #15
So, I screwed the left one all the way in, which stopped all cold water from running in that faucet. In this case the cold is on the left, and the hot is on the right. Not sure if that changes anyone's thoughts on what they suspect as the issue?
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
1 Week Old Shower - Water Pressure Disappeared? ClarendonCondo Plumbing 8 10-18-2009 05:41 AM
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 10:53 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
Hot water pressure in the shower Randy Stuempfig Plumbing 15 01-03-2008 09:58 AM
