Low Hot Water Pressure In One Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2012, 08:48 AM   #1
Low hot water pressure in one faucet
have recently had low pressure in only our kitchen sink..nowhere else in the house(bathrooms etc.)...pressure can start out ok but then it falls off to a small stream...can it be the line that goes from the copper pipe up to the faucet?...the shut off valve seems to be open...haven't touched a thing...and, I've never drained my hot water tank..(12 yrs old)...
Peter Szymaszek is offline   Reply With Quote
Old 02-13-2012, 09:25 AM   #2
Rewards Points: 582
more info is needed single control,make ..seems to me you have a restriction between valve and faucet..
Old 02-13-2012, 05:13 PM   #3
Rewards Points: 24
When was the last time that you removed and cleaned or replaced the aerator?
Old 02-13-2012, 05:32 PM   #4
Lightfoot's Avatar
Rewards Points: 272
beat me to it
I gotta learn to type with more than two fingers
Lightfoot is offline   Reply With Quote
Old 02-13-2012, 06:27 PM   #5
Rewards Points: 582
from what he explained its just the hot side thats slow...starts fast then slow down....if it is a single handle probably in small tube on hot side...
Old 02-13-2012, 07:50 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 356
If you start with good pressure and then it falls off it's not the aerator. Either the stop or supply line is restricted. Does turning off the faucet allow pressure to rebuild?
Old 02-13-2012, 08:28 PM   #7
Lightfoot's Avatar
Rewards Points: 272
Ep,
it may not be the case the majority of the time, but it was-- in a rental i bought last year. It would start out strong, and within a few seconds went to a small stream. Pulled the aerator off, ran it full blast, looked like coffee grounds in there.
Either way, it doesn't cost the OP anything to find out.
Just trying to help.
Old 02-13-2012, 09:48 PM   #8
Plumber
Rewards Points: 356
Originally Posted by Lightfoot View Post
Ep,
Fair enough. But I don't buy it. I gotta see to believe
Old 02-13-2012, 10:06 PM   #9
Rewards Points: 582
Ep,
good point lightfoot ...really he has nothing to loose ben
Old 02-13-2012, 10:35 PM   #10
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Id start with the shut off valve for hot water under the sink and see how much pressure he has there
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
ben's plumbing (02-13-2012)
Old 02-14-2012, 05:04 AM   #11
Rewards Points: 24
For what it's worth, although I mentioned it, I agree; the fact that it starts fine and drops off is not typical of a clogged aerator, but if I were standing in front of it, and only had a verbal description of the problem to start with, I would still take the 30 seconds or so to check it out and put it behind me. We've all seen $5000 solutions for $50 root problems. After that, I'd move to Plummen's suggestion.
Old 02-14-2012, 09:06 AM   #12
Plumber
Rewards Points: 356
Especially if only the hot has low pressure
Kitchen faucet low water pressure apt238 Plumbing 4 05-04-2011 04:38 PM
cold water pressure low in new faucet tndale Plumbing 1 03-16-2011 03:15 PM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 07:04 AM
Decreased water pressure in home Gordon07 Plumbing 3 12-03-2009 12:44 PM
Installing Sprinklers appear to have caused Water Pressure to DRASTICALLY increase geminigirl Plumbing 3 11-12-2009 01:04 PM
