Low Hot Water Pressure In Kitchen Only - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-22-2009, 02:40 PM   #1
Low hot water pressure in kitchen only
House was replumbed with copper pipes within the last ten years. Kitchen has sink faucet and dishwasher, both with low pressure. I replaced the shut off valves and the flex line to the dishwasher. (I also replaced the water inlet valve in the dishwasher and made sure the impeller wasn't clogged.) Took the faucet spray handle apart; no obvious clogging. If I remove the entire handle the pressure improves a little. So I'm assuming the problem is a clog in the pipes. Is there a way to flush them?
nemotode is offline   Reply With Quote
Old 01-22-2009, 05:20 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 628
Ayuh,... Which Handle,..??
While it's possible you have clogged pipes,...
I would sooner think it's 1 of the fixtures....
Plugged copper lines in only 10 years would be some Nasty azz water....
Bondo is online now   Reply With Quote
Old 01-22-2009, 08:25 PM   #3
Building and plumbing
USP45's Avatar
Rewards Points: 150
Check the aireator. There is a water saving washer in there. Throw it away, Another culprit is if the sink is fed off a 1/2" tee then that will reduce pressure too. All fixtures should be fed from a 3/4" line only.
USP45 is offline   Reply With Quote
Old 01-22-2009, 08:48 PM   #4
low pressure
1/2" pipe is right.take off supply line and open angle stop and check pressure with a 5 gal. pucket if pressuse is good it is your faucet.did you always have this proble.....need more info, to fix your promble.NO stub out to a to plumbing is 3/4" only the main feed is.why you think all angle stop are made 1/2" ?
drunknmaster is offline   Reply With Quote
Old 01-22-2009, 09:11 PM   #5
USP45's Avatar
Rewards Points: 150
What I mean is it is code here that all 1/2" lines to any fixture must tie directly into a 3/4" main or larger. Of course the stub out is 1/2".
Old 01-22-2009, 11:26 PM   #6
just glad to infor you..u r welcome burpo
Old 02-02-2009, 02:46 PM   #7
Thank you all for your help. I resolved the problem, which was, indeed, something wrong with the spray arm. This is a Price Pfister one handle faucet with a pull out spout/spray arm, several years old. I contacted Price Pf for assistance, not really expecting any, but instead they told me it was still under warranty (though I never registered it) and sent me a new one for free. In five days. I took the time to write this in case other people experience a similar problem with these faucets, and because I was amazed by their customer service.
Old 02-02-2009, 05:19 PM   #8
Registered User
Termite's Avatar
Good to know how it worked out. Also good to hear that PF took good care of you.
Tags
hot water , kitchen only , low pressure
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 10:50 PM
Hot water pressure help jcrystal323 Plumbing 6 12-31-2008 02:48 AM
Water pressure and temperature billvasko Plumbing 9 06-02-2008 10:23 AM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
water pressure problem rgmetro Plumbing 6 04-09-2007 04:57 PM
