Old 03-31-2008, 12:54 AM   #31
Low hot water pressure- Kitchen only
Ok, don't force it. you don't want to break it. lets start this over. put the nut back on. do you have copper pipes or steel pipes? and this is only on the hot side correct?
plumber Jim is offline   Reply With Quote
Old 03-31-2008, 12:59 AM   #32
does your shutoff valve under your sink look kinda like this?
or a straight version.
Old 03-31-2008, 01:23 AM   #33
Shut off looks like picture you show ,copper pipes below shut off, flexible above.
Low flow on hot side only.
tcpnkc@hotmail.com is offline   Reply With Quote
Old 03-31-2008, 01:29 AM   #34
Well, I would check to see if the pressure is poor at the supply tube. if it is i would shutoff teh main water to the house and open the lowest faucets in the hose to drain it down then romove the stem from the shutoff under the sink. the nut just behing the handle. you can see it in the picture, the washer should be on the end. if it is not it is jammed in the valve. just remove it. of course you would need a new valve then. I have to call it a night. I will check back with you tomorrow.
Old 03-31-2008, 01:47 AM   #35
thanks for your help.
I'll give your last suggestion a try tomorrow
Old 03-31-2008, 08:53 PM   #36
How has your pressure problem going?
Old 03-31-2008, 10:25 PM   #37
I have made no attempts to solve the issue since last night.
Just got home from work 8pm local.
I'm leaning towards hiring a proffesional.
Old 03-31-2008, 10:32 PM   #38
Journeyman Plumber
Ron The Plumber's Avatar
Might be a wise thing to do.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 03-31-2008, 11:04 PM   #39
Ok, Good Luck, Feel free to email me if you have any questions I will try to answer.
Old 04-01-2008, 09:43 AM   #40
You know what could have saved a lot of typing? A private message with a phone number.
perpetual98 is offline   Reply With Quote
Pressure Fluctuation with well water beertestr Plumbing 5 10-03-2007 10:18 AM
Water pressure? What water pressure? mnp13 Plumbing 9 05-03-2007 03:32 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 10:04 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 07:55 PM
