Low Hot Water Pressure- Kitchen Only - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-30-2008, 09:38 PM   #16
Journeyman Plumber
Ron The Plumber's Avatar
Post a picture of it if you can.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-30-2008, 09:39 PM   #17
look at this link below. is that the faucet?
http://www.homedepot.com/webapp/wcs/...401+501572+835
http://www.broomfieldplumber.com
plumber Jim is offline   Reply With Quote
Old 03-30-2008, 09:57 PM   #18
Plumber Jim that is not the one.
It is discintinued.
I'll try to post a pic
in the meantime it looks someting like this
http://www.faucetdepot.com/deltadepo...tCategoryId=28
tcpnkc@hotmail.com is offline   Reply With Quote
Old 03-30-2008, 10:10 PM   #19
Journeyman Plumber
On that faucet there a tab that gets removed to access the set screw on the front of the handle, you don't see that there?
Old 03-30-2008, 10:22 PM   #20
really feeling like a newbie. The tab that is removable is the red/blue symbol signifying hot/cold. It ia a rubber piece that pops out with fingernail.
Old 03-30-2008, 10:24 PM   #21
Thats it.
Old 03-30-2008, 10:49 PM   #22
OK , there is a blue outer Washer, is this the retaining nut?
If so, it does not come off easily and I'm afraid I'll break it.
Old 03-30-2008, 11:06 PM   #23
the nut should be the same color as the finish of teh faucet.
Old 03-30-2008, 11:10 PM   #24
thanks for your patience.
Got the nut off, but nothing remaining seems to budge.
Old 03-30-2008, 11:19 PM   #25
I see a plastic piece in the center that is controlled by the handle that I removed.
Surrounding this is what looks to be a hard plastic washer.
I have tried to pull up the center piece as well as the outer "washer".
Nothing moves. What is holding it in place?
Old 03-30-2008, 11:19 PM   #26
do you see a metal or plastic lever? should be back and forth.
Old 03-30-2008, 11:33 PM   #27
plastic lever
Old 03-30-2008, 11:35 PM   #28
ok, then you have a cartridge and it can be pulled out.
Old 03-30-2008, 11:45 PM   #29
after you remove it you can cover the fuacet with a towel and open the shutoof valve and flush it. also look at the inlet under the cartridge to see if the cartridge got something blowup into it. after that put it all back together and see if that helped. also did you say that its only on the hot side that you have low pressure? if so you can remove the supply line on the hot side assuming its a flex like and open the valve with the flex line in a pitcher say 1 gallon and time how long it takes to fill. that way you can see how many gallons a minute you get straight from the supply tube. then do the same from the faucet and compare the two. If you get low flow from the supply tube it can be clogged or the washer be stuck to the seat in the valve itself.
Old 03-30-2008, 11:49 PM   #30
So it can be pulled out? I have tried by hand and pliers to lift it straight up and out. It won't budge
Pressure Fluctuation with well water beertestr Plumbing 5 10-03-2007 09:18 AM
Water pressure? What water pressure? mnp13 Plumbing 9 05-03-2007 02:32 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 09:04 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 06:55 PM
