Low Hot Water Pressure But Cold Is Fine - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-31-2009, 04:46 PM   #1
Question
I bought this mobile home and it has low water pressure but the cold water pressure is fine. The hot water still gets really hot but just no pressure.
THartman2 is offline   Reply With Quote
Old 08-31-2009, 07:20 PM   #2
biggles's Avatar
if all the hot water sides are the same evn with the air aters off the spigots then you probably have a mineral build up.the hot copper line just out of the top of the HWH is resticted down with .........STUFF.the lead out pipe needs to be removed/cleaned or replaced
Old 09-01-2009, 01:49 PM   #3
So I'm assuming if the hot water pressure is bad in a just one of the spigots throughout the house, it's just that particular spigot with
build up or a clogged pipe?
Our shower spigot does this and rattles when using both hot and cold water or the "middle" of the dial. The hot water pressure on all other spigots are fine throughout house.
cyfehr is offline   Reply With Quote
Questions about water pressure regulation.. MrSimmonsSr Plumbing 21 05-13-2017 07:08 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
no cold water pressure to 2nd story chellecalvin Plumbing 2 02-09-2009 11:38 AM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 10:29 AM
Water pressure and temperature billvasko Plumbing 9 06-02-2008 09:23 AM
