Old 11-19-2012, 08:19 AM   #1
Low hot water pressure at all Faucets and showers
I get my hot water from a peerless boiler. Low pressure does not affect baseboard heat that works fine. When I turn on a faucet or shower the hot water pressure drops to a trickle in about a minute. If I turn the faucelt off and wait a minute pressure rebuilds and then will drop to a trickle again in about a minute. What could this be???
wlee239 is offline   Reply With Quote
Old 11-19-2012, 08:48 AM   #2
Lightfoot's Avatar
first thing i would try would be to take the aerator off and flush the faucet out good, also take the supply lines loose (which connect to the faucet) and flush them out good. Also the shower heads-take them off and run the hot at full throttle without the head on. Be sure and clean the rear of the shower heads too. Sounds like you may have some crud in the lines building up behind the aerators and shower heads.. That may or may not be the problem, but it won't cost but a few minutes of your time to rule it out.
Lightfoot is offline   Reply With Quote
Old 11-19-2012, 09:45 AM   #3
I tried cleaning the aerators and flushing the lines that had little effect.
Old 11-19-2012, 10:21 AM   #4
Super Moderator
Are you from the UK?
oh'mike is online now   Reply With Quote
Old 11-19-2012, 10:24 AM   #5
Old steel pipes?
Been doing any plumbing work before this happened?
City water or well.
Old 11-19-2012, 10:30 AM   #6
Not from the UK, in the USA
All Copper piping, I havent changed any of the plumbing.
And it's well water.
Old 11-19-2012, 10:57 AM   #7
Check your pressure tank. Low on air or a blown bladder can cause this.
See if the pump turns on the instant you open the faucet.
Old 11-19-2012, 11:24 AM   #8
on the pressure tank how much pressure should be in the tank? I just checked the pressure tank. I show 28 PSI at the bottom of the tank and 38 PSI at the top of the tank.
No Water Pressure ssbsts Plumbing 4 01-15-2012 01:36 PM
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 09:35 AM
Water pressure regulator question Mrdippy Plumbing 0 01-27-2011 01:47 PM
Confused! Water Pressure mmoore58 Plumbing 5 01-02-2011 05:54 PM
Hot water pressure help jcrystal323 Plumbing 6 12-31-2008 02:48 AM
