Old 01-05-2011, 10:30 PM   #1
Low hot water pressure
I have low hot water pressure in my bathroom. It started after replaced the heating elements in my water heater. How do i clear the line
keith08 is offline   Reply With Quote
Old 01-05-2011, 11:58 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Sediment debris from the water heater has probably clogged the hot water side shut-off valve(s) and/or the hot water side of the tub/shower and sink faucets.
Turn the water off to the water heater if you have a cold water supply valve to it (which only shuts off the hot water of course) or turn off your water main valve.
Dismantle the hot water shut-off valve(s) and faucets in the bathroom. Put towels under and over the shut-off valve under the sink and over the faucet. Have someone VERY briefly turn the water pressure back on to flush the debris out and then turn it back off very quickly.
That should clear it out. If it doesn't, you may have to take a piece of stiff wire (coathanger?) and break up the debris clog while the water is off and then flush it out.
Works for me.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 01-06-2011, 10:57 AM   #3
Help since before xmas we have had low hot water pressure and the cold has got little black bits in looks like carbon any ideas please
dave1066 is offline   Reply With Quote
Old 01-06-2011, 02:02 PM   #4
Homerepairguy's Avatar
You should drain and flush your water heater before any attempts to clear the clog. Otherwise you could just be sending more crud into your hot water line resulting in ongoing clogging problems.
Also, if there is crud from your heater blocking your bathroom hot water line, there is probably crud in all of the other hot water lines as well. You should flush all hot water lines in the whole house to avoid ongoing problems. I have a procedure (that I never tried but believe will work) to reverse flush the hot water lines without disassembling the working hot water faucets. It's a long procedure which includes the heater drain and flush. Let me know if you want to try it and I'll post it. I'll also have to know if there's a heat trap check valve in your hot water line above the heater.
HRG
Homerepairguy is offline   Reply With Quote
Old 01-06-2011, 02:05 PM   #5
Those black carbon looking bits are probably pieces of black rubber (old ones are hard) broken off from a valve.
HRG
Old 01-07-2011, 02:34 PM   #6
Plumbing Solutions, LLC
PlumberinSC's Avatar
I would suggest flushing the water heater.
Plumber in SC
PlumberinSC is offline   Reply With Quote
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 05:23 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
Low water pressure upstairs but gauge reads 100psi? rivers72 Plumbing 7 11-15-2008 08:55 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
