Low Hot Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-27-2010, 11:49 AM   #1
Question
Low hot water pressure
Over a week ago I noticed the hot water pressure getting lower.
I have already had the pipes and pressure values replaced 2 years ago, in addition to replacing the hot water tank 4 years ago. I am currently draining the hot water tank to flush ( hopefully) all of the junk out.
I would welcome any suggestions that anyone has to let me know what else I should do to increase my hot water pressure. Is there anything I can put in the tank to disolve any of the junk? If so what is it and how do I put the stuff in the Hot water tank.
The cold water pressure is outstanding and has no problem.
H20BEAR is offline   Reply With Quote
Old 09-27-2010, 12:09 PM   #2
Just call me Andrew
Rewards Points: 1,020
Check out this post from AllanJ a couple weeks ago:
Hot water pressure problem
Andrew
secutanudu is offline   Reply With Quote
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 04:23 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
Low water pressure upstairs but gauge reads 100psi? rivers72 Plumbing 7 11-15-2008 07:55 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
