Low Hot Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-11-2010, 07:24 PM   #1
low hot water pressure
My house is about 2 years old and is heated by a oil fueled boiler system. When we first in moved the hot water kept losing its hotness and had to have the temperature control valve replaced because it was clogged. I have also found over time the pressure keeps going down for the hot side. All faucets and the tubs in the house are the same. Cold water pressure is fine thru out the house. There is a water filter that is change every three months attached to the cold water line after the well tank. When the filter is changed do you need to bleed any air out of the line? Also the well tank has not been flushed since the house was built. There is also a round gray tank that holds the hot water for what appears to be the heating system. It has a valve underneath and do not know if this will also need to be flushed?
Any help will be appreciated.
Flan
flan is offline   Reply With Quote
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 05:23 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
Low water pressure upstairs but gauge reads 100psi? rivers72 Plumbing 7 11-15-2008 08:55 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
