Low Hot Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-05-2009, 06:30 PM   #1
Low hot water pressure
Hello i lost hot water pressure in my whole house. I have a EFM electric oil furnace. I did change the hot water coil last year and it was working fine. I also checked the valves and they are all open. Can anyone help me narrow down the problem. When i turn on the hot water i get some steam and then very little water.
HARTZELL is offline   Reply With Quote
Old 12-06-2009, 10:24 AM   #2
My first guess is that the mixing valve is probably clogged with scale. When you replaced the coil, you may have disturbed the coating of scale/sediment/rust etc lining the inside of the pipes which could've clogged the mixing valve. You may also need to unclog some hot stems/valvets at the sink faucets and some aerators as well.
Ishmael is offline   Reply With Quote
Old 12-07-2009, 11:17 AM   #3
low hot water pressure
Thanks and i will let you know how i make out. this is a big help.
Questions about water pressure regulation.. MrSimmonsSr Plumbing 21 05-13-2017 07:08 PM
Decreased water pressure in home Gordon07 Plumbing 3 12-03-2009 11:44 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
