-   -   Low hot water pressure (http://www.diychatroom.com/f7/low-hot-water-pressure-58594/)
HARTZELL 12-05-2009 06:30 PM
Hello i lost hot water pressure in my whole house. I have a EFM electric oil furnace. I did change the hot water coil last year and it was working fine. I also checked the valves and they are all open. Can anyone help me narrow down the problem. When i turn on the hot water i get some steam and then very little water.
Ishmael 12-06-2009 10:24 AM
My first guess is that the mixing valve is probably clogged with scale. When you replaced the coil, you may have disturbed the coating of scale/sediment/rust etc lining the inside of the pipes which could've clogged the mixing valve. You may also need to unclog some hot stems/valvets at the sink faucets and some aerators as well.
HARTZELL 12-07-2009 11:17 AM
low hot water pressure
Thanks and i will let you know how i make out. this is a big help.
