Low Hot Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-31-2009, 10:10 AM   #1
low hot water pressure
just to be short had plumber install a tankless water heater, before water heater is a water softner and a whole house water filter. getting low water pressure from cold and hot when i use washer. bought the larger tankless water so this would not happen but it does. using a GE GXWH20F water filter with a CULLIGAN softner. tried looking up possibilities could not find any maybe someone here might a few suggestions. thanks
p.s. before job was done everything was fine pressure wise.
marin001 is offline   Reply With Quote
Old 08-01-2009, 03:48 PM   #2
Make sure your water main is all the way open and put your filter on bypass then try again.
plumber Jim is offline   Reply With Quote
Old 08-01-2009, 05:45 PM   #3
did just that today, water pressure is much better so i quess the whole house water filter i am using is lowering my pressure. any suggestion on how i can get better pressure without removing filter, if not i quess i am going to have to remove it and just put it for kitchen cold water.
Old 08-01-2009, 11:07 PM   #4
Well, if you have 3/4" pipes try using a filter designed for 1" and reduce to 3/4" the 1" filter should be larger which would have less restriction. Just a thought. also look at the flow rates of the filters you use.
Questions about water pressure regulation.. MrSimmonsSr Plumbing 20 11-30-2012 09:43 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Water pressure? What water pressure? mnp13 Plumbing 9 05-03-2007 02:32 PM
