Old 04-21-2009, 05:53 PM   #1
low hot water pressure
The hot water pressure in my house is very low and the cold is good. I have a low pressure boiler and I was told the pipes coming from the heater tank on the boiler may be clogged, the problem is I do not see any heater tank on or connected to the boiler. The only tank I see is where the water comes into the basement from the well it is a big blue tank and the pipes go from there to the boiler.
misa9498 is offline   Reply With Quote
Old 04-21-2009, 08:13 PM   #2
Safe, Most of the Time!!
brokenknee's Avatar
Check to make sure someone didn't partially close the valve leading to the boiler.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 04-21-2009, 11:07 PM   #3
It's either a valve somewhere or a clog. That clog could be anywhere though but will likely be somewhere that is smaller such as a standard valve(vs. a 1/4 turn). Just for future reference the blue tank is a pressure tank. It provides constant pressure to you house as well as holds water so your pump only turns when the pressure falls below a pre-determined value, usually around 18 psi. Meaning the pump doesn't turn on every time you turn the water on.
joel v. is offline   Reply With Quote
Old 04-22-2009, 04:55 AM   #4
brokenknee's Avatar
My well kicks on at forty PSI and shuts off at sixty not eighteen.
Old 04-22-2009, 03:04 PM   #5
You can get different pressures. I wasn't aware that they went that high. As far as I can remember the one at the old farm went from about 18-45 psi.I can't tell if your making a pointless statement or bragging.
Old 04-22-2009, 04:16 PM   #6
brokenknee's Avatar
Neither, 18-45 just seams pretty low if we are talking about well water pressure. Most of the wells that I have seen are set around the 40-60 range.
The pressure on mine is adjustable, I know an RO system will not work below 40psi.
Old 04-22-2009, 10:32 PM   #7
thank you Joe V, I think it may be the valves are very old
Questions about water pressure regulation.. MrSimmonsSr Plumbing 20 11-30-2012 10:43 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Water pressure? What water pressure? mnp13 Plumbing 9 05-03-2007 03:32 PM
Bad water pressure (well water) fnkyniedls Plumbing 2 10-23-2006 12:42 AM
