Low Hot Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-18-2009, 05:05 PM   #1
low hot water pressure
I have recently had my kitchen renovated, the plumbing was moved, since then all the hot water in the house has very low pressure. Ideas?
Tashie is offline   Reply With Quote
Old 04-19-2009, 05:06 PM   #2
Something internal has broken loose and went downstream inside the pipes until it encountered an opening too narrow to pass.
You could confirm you are getting at least 6 GPM at crucial points, like the drain cock for your water heater.
Questions about water pressure regulation.. MrSimmonsSr Plumbing 21 05-13-2017 07:08 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Water pressure? What water pressure? mnp13 Plumbing 9 05-03-2007 02:32 PM
Bad water pressure (well water) fnkyniedls Plumbing 2 10-22-2006 11:42 PM
