Low Hot Water Pressure... - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-15-2012, 10:16 AM   #1
Low hot water pressure...
My neighbor and I live in a small 2 apartment building and share the hot water heater and was working fine up till about 6 months ago and since then we have noticed a slow and steady drop in pressure. Its so bad now that the hot water is almost a trickle and also will literally stop running at all for a few seconds every few minutes and then start back up with the typical low pressure.
Twice we have tried draining the tank and its always clear. Also a friend was saying that since the water is flowing from the drain valve properly that its not a problem with the tank itself (not sure how true this is).
I guess my big question is... what on earth would be causing the pressure to be so low and also why would it stop and start every so often? Cold water pressure is fine. Its a standard water heater... not sure how old.
BCrossan is offline   Reply With Quote
Old 12-15-2012, 12:26 PM   #2
Rewards Points: 13,694
Old steel pipes?
Old gate style shut off valves?
oh'mike (12-16-2012)
Old 12-15-2012, 12:30 PM   #3
Lightfoot's Avatar
Rewards Points: 272
first thing i would try is take off the aerators from faucets and flush out the lines. do the same with shower heads.
Lightfoot is offline   Reply With Quote
Old 12-15-2012, 02:05 PM   #4
Originally Posted by joecaption View Post
Old steel pipes?
Everything is done in PVC piping and ball valves/
Old 12-15-2012, 02:06 PM   #5
Well the bathroom and kitchen sinks don't even have aerators.
Old 12-15-2012, 10:50 PM   #6
Rewards Points: 744
It's an apartment...call in the landlord/maintenance man.
Seattle2k is offline   Reply With Quote
Old 12-16-2012, 12:03 AM   #7
If we sat around waiting on the landlord to either fix/replace/research the issue we would end up smelling like 10 day old trash sitting out in the dead of summer. I been here for a year and still cooking out of counter-top griddle cause he hasn't replaced the broken stove and walking around on concrete floors just as long cause he never replaced the wet moldy carpeting after a flood.
Old 12-16-2012, 01:10 AM   #8
Rewards Points: 366
How do you put up with such a landlord? Bargain rent or stuck on lease contract for a while?
daluu is offline   Reply With Quote
Old 12-16-2012, 01:48 AM   #9
More like traded my car to keep a roof over my head while I battle with Social Security.
Old 12-16-2012, 06:28 AM   #10
DIY staff
Rewards Points: 7,174
If the drain cock works--turn it on---if it blasts out water--you have good pressure to the tank---if it runs slow----the problem is at or before the tank----
Let us know----
Old 12-16-2012, 08:42 AM   #11
Open drain and its good pressure
Old 12-17-2012, 12:27 AM   #12
Special User
Rewards Points: 1,230
Could be a gunked-up energy-saving device on the hot water output at the top of the tank. Little marble that's supposed to keep the hot water in the tank until called for. Should be easy to close the cold side cutoff valve, disconnect the pipe to the hot side, dig the marble out, and throw it away.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-17-2012, 07:29 AM   #13
And whats the downside to removing this "marble"?
Old 12-17-2012, 08:25 AM   #14
Special User
Slightly increased energy (gas or electric) costs.
Old 12-17-2012, 09:44 PM   #15
I will have my neighbor take a look and see if this is on there or not... crossing fingers this could be it... cause Im dying for a nice hot shower.
Hot water pressure low (pictures) bluefoxicy Plumbing 4 12-11-2012 07:45 PM
Low water pressure (hot water only) - temp fix when I shut off water supply to tank skilletrx Plumbing 5 11-15-2012 07:37 AM
Check valve gimaarob Plumbing 13 10-27-2011 10:13 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
