Low Hot Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-24-2012, 01:41 PM   #1
Please HELP... have very little hot water pressure through out the home and my hot water heater will not drain. what do i do ??
tkrell21 is offline   Reply With Quote
Old 09-24-2012, 01:52 PM   #2
joed's Avatar
Rewards Points: 12,016
Sounds like the tank might be full of sludge. New tank might be needed if you can't get it to drain and clear out.
The Following User Says Thank You to joed For This Useful Post:
tkrell21 (09-24-2012)
Old 09-24-2012, 02:13 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 452
The drain is plugged with sediment. Depending on the design, you might clear it with a stiff wire. Or try opening it 100% and then closing the drain valve slightly- works sometimes.
Also check to see if the hot water out nipple is plugged.
As stated, you may need a new heater.
Check valve gimaarob Plumbing 13 10-27-2011 11:13 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 08:24 PM
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 05:23 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
